ВАЗ 2108. Історія, цікаві факти.
Повідомлення vovka » Сер, 14 березня 2007, 13:16
Натрапив на цікавий сайт:
http://digilander.libero.it/cuoccimix/E ... (lada).htm
Відкрив для себе багато нового, раджу всім прочитати :)
Декілька цікавих фактів:
Up, others versione of "Samara": the new "Samara" sedan (also called "Forma"), the last hatchback version, a truck version. The aerodynamic (Cx=0,36) was sufficient, the stability was good (the vote was "five stars"- the maximum- on the italian review "Quattroruote"!), but the suspension, for this, were terribly hard, and the rumble of the engine -good about the performance- very high. The construction, usually for the Eastern cars, was of poor quality, but better than other Eastern cars.
З аеродинамікою наплутали, насправді Cx=0,46.
"Samara-EVA" of the 1987, with a 1860 cc. engine (16V, turbocharger, electronic injection, 300 hp!), placed centrally, derived from the "Zhiguli-2106"...although the only part remained from the "Zhiguli" engine is the cylinder block, and of the "Samara" there are only the shape of the coachwork -realized in fiberglass- and the headlights!! It was realized also in other versions without supercharger (160 hp)
Я в шоці. В далекому 87 році ВАЗ зумів поставити 16v, турбіну, і інжектор. Чого ж на конвеєр інжектор і 16v ГБЦ пішла значно пізніше... :(
Another very powerful version was the "Samara T3" (four pics above), that also won a Pharons Rally in Africa...but this version, indeed, hasn't Lada parts: it had a Porsche six-cylinders engine, 3600 cc, 300 hp, 220 km/h!
Made in the 1989 by the Russian "NAMI" Research Institute (the author was M. Menzulov), it was called NAMI "0290-Appelsin" ("appelsin" stands for "orange" in Russian); it had the engine of the "Zhiguli", 1600 cc, equipped with a Mitsubishi turbocharger, for 180 hp and 210 km/h. The transmission was permanent 4WD with viscous joints, with a torque ripartition of 50:50% between the axles. The side doors were taken from the ZAZ "Tavria", the rear lights from the "Samara". The total weight was 960 kg.
Ще про Лади тут:
http://digilander.libero.it/cuoccimix/E ... lada2).htm
Нажаль всьо саме цікаве закінчилося на ВАЗ 2108. А далі щось всьо розвалилося і так нічого нормального я не знайшов.
